Fuel filter
UT
Fuel filter
http://h1070313.hobbyshopnow.com/pro...p?prod=DYN2026
http://h1070313.hobbyshopnow.com/pro...p?prod=AXI0505
I'm using a fuel filter like the one in the first link. At first, it worked fine and improved performance by quite a lot.
Now, even with everything the way it was, the actual filter (second link) blocks the little hole where fuel enters the engine... In other words, the fuel will enter the canister fine, but it will not leave it so fuel cannot travel at all due to the pressure. Is there any way to fix that?
I'm not sure if I'm making enough sense, so just ask me if I'm too confusing...
UT
RE: Fuel filter
What filter stone? I didn't take anything out...
When I took the line off the gas tank, I tried blowing and no air came out the other side. That is what I mean.
UT
RE: Fuel filter
http://h1070313.hobbyshopnow.com/ser...=ALL&tag=qsrch
Have you used any of these? I can't open the packaging at the LHS so I'm just gonna ask people with experience.
CA
RE: Fuel filter
I think maybe the reason it was increasing your engine performance is because it was leaning out your car. That will ruin it and i agree with Collector. Buy one with an aluminum screen. That won't clog any and it won't lean out your engine.
