Connecting Rod of ofna .25 .28???? HELP ME
Place a piston and cylinder motor force .28 in a .25 engine but this does not react ... I have already tried at least carbide but neither gives ...
The length of the connecting rod of engine .28 is larger than .25 engine?
PA
RE: Connecting Rod of ofna .25 .28???? HELP ME
so let me get this straight, you're trying to put a cylinder and piston from a .28 into a .25 motor, right? the rest of what you said is kinda confusing. i understand english isn't your first language, so obviously some patience is required
you're saying the .28 piston is smaller than a .25.
the stroke of the .28 is longer than the .25.
not sure what you're saying about the connecting rod.
ORIGINAL: Jaybo
ORIGINAL: twomanytoys
First off you CAN NOT install a .28 anything into a .25 case. If you have a .25 you need to replace it with .25 parts.
As measured wonder why the connecting rod of engine .28 and the measures the connecting rod engine .25?
PA
you gotta find another way to put that... i'm not sure what you're trying to say. maybe if you can post some pics of what you're talking about, it might help.
are you saying the connecting rod of the .28 is smaller than the connecting rod of the .25? or you mean the stroke (the distance the piston moves up and down in the cylinder) is smaller? a .25 might have a smaller stroke than a .28. it all depends on where they're getting their displacement. either bigger stroke or bigger bore. or maybe both. a .28 may have a smaller rod in order for them to achieve more stroke.
