Car Stalls
Car Stalls
Hey guys I got a kyosho dst and everything is working good atleast it seems so. I prime the engine and then I crank start it but it just rumbles and doesnt start.. What do I do? The fuel is fresh and the car is brand new.
RE: Car Stalls
After I put the hair dryer up to it for a couple of minutes it starts pretty good and idles for 10 second seems starved of gas and the tube doesnt seem to get gas from the tank do you have to start a rc car with a full tank of nitro? Please help guys
RE: Car Stalls
You might need to check the o ring on you tank. Take of fuel tube and blow Carefully and softly into tank if you hear air you do not have a tight seal needed for fuel delivery. Its like a vacume seal.
RE: Car Stalls
You may want to turn the idle screw up a little. This will open the needle a bit to let fuel flow better. You can usually bump your throttle on the transmitter while starting and it will fire.
