Nitro engine stalling when it speeds up Help!!
Hi im new to this hobby and i finished the break in process today but my engine cuts out or stalls when it goes over a certain speed also it seems to be spitting out fuel from the exhaust please help! BTW its a .18 team infinity engine.
That depends, if it's stalling while your excellerating... it probably means that your LSN is to lean.if it's already up to rpm, than your HSN could be too lean.... good luck
My Feedback: (10)
IL
I'll be the third one to say that your HSN is too lean.
Richen it up a little bit and see what you get.
As for the residue coming from the exhaust, that's normal. Plug it up with a piece of a paper towel when you are done for the day so that it doesn't leak out somewhere that you don't want it to...that sounded dirty...
