Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
switchin fuel??
Old 11-29-2008 | 08:22 PM
Default switchin fuel??
i wanted to know when i get my truck that i won over on ebay will i have to do anything special to the truck? cuz i will be using the same nitro % as the last owner.Im goin to use traxxas 20 % i think he was using another company other then traxxas. As far as i know the truck is coming from FL and i live in NY.
Old 11-29-2008 | 08:43 PM
46u's Avatar
46u
Default RE: switchin fuel??
Traxxas some of the worst fuel on the market! [:'(] WAY TO MUCH OIL CONTENT! You want something with no more then 12% oil content. Too much oil can make problems just like too little. Being used you need to go over it well.
Good luck and have fun.
Old 11-29-2008 | 08:55 PM
i have some on its way allready. what should i do when i get the truck should i let it idle about a half of a tank and then try to see how it drives, and then addjust the high speed then low speed?
Old 11-29-2008 | 08:59 PM
Montana Mike's Avatar
You should consider ripping the thing apart 100%. Checking everything to see if it is worn. If it is, replace it and tighten everything down. New Glow Plug, new Fuel Filter, clean the Air Filter, charge her up, return carburetor to factory settings, then fire her up. And go from there.
Old 11-29-2008 | 09:03 PM
ok thanks,with the truck im gona get some new glow plugs so im gona put a new one in. i understand takeing it apart and see if there is any issues is one way,how about if i was to start it and go from there and see how it is and then go and see if there is a issue then fix it im just tryin to get it goin soon. Its starting to get cold out in ny .
Old 11-29-2008 | 09:06 PM
you could do that by all means, no problem. However, you do not know the condition the truck was maintained to. If you you do this, you could cause more problems, ruin more things. I would rip it apart if it were me. That way I know things are lubed, tight, and what condition things might be in. That is just me though.
Old 11-29-2008 | 09:11 PM
Ok ill go over it and go from there. so u think i should set the high speed and low speed back to factory specs?
Old 11-29-2008 | 09:14 PM
46u's Avatar
46u
This supports what I have expereinced.
Why 8% to 12% Oil
Using high oil content fuels in gas car engines won't provide improved engine life, as some would expect. Through extensive testing we've discovered the point of diminishing return as far as oil content to engine life is actually around 8% for most car engines. In other words any more oil than 8% in the fuel does noting to improve the life of a car engine. In fact the secondary effects of high oil content fuels can actually cause engine damage by encouraging over lean runs. Here's how.
Using high oil content fuel causes a car engine to be unresponsive during acceleration acting as if the engine were running rich. Typically when using high oil content fuel, in order to get crisp acceleration and response, an engine will need to be adjusted overly lean. In addition the high oil content prevents lean bog when an engine is over-leaned thus allowing the engine to run at this lean setting without the customary telltale lean bog warning letting you know the engine is overheating.
In summary, high oil content fuels don't give added protection. The point of diminishing return from a protection standpoint in a gas car application is about 8% oil depending on the oil type and engine. Anymore oil than this doesn't offer added protection and has potential secondary effects that reduce performance and can actually cause you to over lean your engine in an attempt to get crisp throttle response and acceleration.
Old 11-29-2008 | 09:15 PM
I would. Different elevations, Different settings. Factory settings is a good place to start IMO. What does it have in it?
Old 11-29-2008 | 09:26 PM
it has the .18 engine that i think that comes with it. a new tune pipe ,some metal arms little things. I think it still has a pull start on it. i dont know if i can post a link to the ebay page .
Old 11-29-2008 | 09:28 PM
PLease do, lets check that bad boy out
Old 11-29-2008 | 09:32 PM
ok[link]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170280522287&_trksid=p 2761.l1259[/link] if u look at one of the pics u can see that the front upper arms are metal but the lower arms are still plastic. Or am i seeing this wrong ?
Old 11-29-2008 | 09:34 PM
46u's Avatar
46u
You will learn about alloy A arms. Yes i agree you need to go over the whole thing.
Old 11-29-2008 | 09:35 PM
ORIGINAL: 46u
what u mean i will learn about alloy A arms. in the past i would use rpm arms for my traxxas cars/trucks
Old 11-29-2008 | 09:36 PM
Looks like a nice rig. Yes the lower front are still plastic. Nothing wrong with that though. ALl aluminum rigs do not have much room for flexing. LOOKS nice, but not as practical in my opinion
Old 11-29-2008 | 09:43 PM
thanks for 125 its not bad . what u think of the remote and can u see any issues in the pics? what u mean practical?
Old 11-29-2008 | 09:45 PM
46u's Avatar
46u
Alloy bends not flex like plastic and will all so pass breakage on to the next weakest point. I know this from experience. Both look like alloy to me in the picture.
Old 11-29-2008 | 09:47 PM
if u look u can see the top is metal and if u look all the way down u can see that there is some black plastic.
Old 11-29-2008 | 09:53 PM
46u's Avatar
46u
To me both upper and lower look silver so I would guess alloy on the rear and yes after looking again the front look like just the upper. Have to wonder why this is.
Old 11-29-2008 | 09:58 PM
i dont know the guy said it drives good and handles great. he said he does not have an issue with it fliping over alot. I like the fact that he never ran it with out the body on . I guess ill just do the waiting game and see how it is when it comes. i got some new fuel tubeing and a fuel filter and some other stuff. Im gona have to pick up a new fail safe and i wana get a reciver battery pack. i sold my tmaxx with my fail safe and reciver pack wich i think was stupid.
Old 11-29-2008 | 10:01 PM
I have aluminum bulkeads on my T- Maxx. But my a- arms are still the nylon filled plastic. The plastice will flex under pressure, as where the aluminum will bend. Plactic $5.00 Aluminum $15.00. Just not practical. The impact is taken out in the plastic a- arms. If I had aluminum, the stress would be passed form the a- arms to the bulkheads. Possibly ruining both. But the aluminum bulkheads gives me more rigid frame for the trucks, allowing the weak points to flex with the plastic. Make sense?
Old 11-29-2008 | 10:08 PM
it does im gona see how i like it i have a hugh open spot i can go to see how i like it. i will only be able to drive it for about 2 weeks i have to have hand surgery on my right hand then my left. so i have to rush to get this thing goin to see if there is any issues. anyways thanks guys for all your help and i will post some pics when i get it and post if there is any issues i come across that i can not fix.
