glow plug life
IL
RE: glow plug life
I change it probably every 1.5-2 gallons.
EDIT:not because the engine won't run anymore....but the idle could suffer a little bit, or I just know that i've had the same plug in for a couple of gallons and it probably would be in my best interest to just change it out.
FL
RE: glow plug life
Checking your glow plug should be routine maintenance. When you do your post run clean up you should check your glow plugs glow element. If it is distorted, really dull grey, etc.. it should be replaced. Glow plug life varies depending on nitro %, tuning, etc.. Most people forget glow plugs are disposable.
RE: glow plug life
I always check my glow plug at the end of each run. I do notice the very tip of the silver coil in the glow plug is black. My plug is only new! Is this normal?
RE: glow plug life
That is normal at the very tip (1-2mm) where the coil connects to the shell of the plug. It's black because it runs a lot cooler at this point because it's attached to the shell than the rest of the coil.
But yea just wanted to chime in that I usually get 2 gallons on average per plug. Some I've had last 3-4 gallons, but I usually swap out at 2 gallons regardless. One time I could not for the life of me get my truck to tune or run right. Found out the plug was going, despite it looking fine when inspected. The new one completely fixed all issues. I'd make it habbit to swap em out at the 2 gallon mark though. (And at the 3/4-1 gallon mark on new engine break-ins).
RE: glow plug life
Longest life I got out of a single plug has been for about 3-4 gallons. I ran the same plug from break in until I noticed the engine was having harder starts. If you are tuned well, your plug will last a long time. Running both rich and lean will foul plugs quickly, you need to find a good tuning window where your engine/plugs are happy.
Tom.
Tom.
