Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Pitted Button
Old 08-24-2009 | 08:58 PM
Default Pitted Button
Can you use a head button that has slight pitting (caused by a blown bearing). I have lightly sanded the pitts. The sleeve/piston etc all ok. Will the compression be changed too much? The pitting is not in the chamber of the button, just on the flat edge.
I have ordered a new button but would like to try the sanded one while waiting.
Old 08-24-2009 | 10:05 PM
SManMTB's Avatar
Default RE: Pitted Button
It'll work fine.
Old 08-24-2009 | 10:44 PM
absolutemayhem's Avatar
if you sanded it down pertty good, take out one thin shim...should be good to go....
Old 08-26-2009 | 12:34 PM
controlliner's Avatar
If you radiused the edge between the "bubble" and the squish band, it can affect the power output. The best remedy is to put the button in a lathe and set the cross slide at 5 degrees and take 2-3 thou off the squish band face.
Old 08-26-2009 | 08:34 PM
I slightly sanded the squish band. It still has slight marking on it. The good news is it works ok with no power loss. I have a new button on the way just in case.
Old 08-27-2009 | 08:17 AM
About the only way you will notice a power loss is on an engine dyno. Wow, we had an AC/DC concert in our city last night, I live 10 Km away from the stadium and I heard it[sm=eek.gif][sm=eek.gif][sm=eek.gif]
