Locked engine
ON, CANADA
Locked engine
hey, i have a savage 21 nitro, i was running it the other day it ran perfectly fine, then i put it away before i did that i put some after run oil in the carb and engine, today i go and try it, i can't pull on the pull start, i took off the head and the piston won't budge at all, i dunno what happend, any suggestions??
thanks!
thanks!
RE: Locked engine
If the motor cooled whilst the motor was at TDC, the sleve could have shrunk around the piston and caused it to lock. Try heating the engine with a heat gun or hairdryer and give it a go, assuming the rod isnt bent.
ON, CANADA
RE: Locked engine
i've taken the engine out of the truck, and taken the pull starter off the engine as well, tried spinning the shaft and all i hear is a clicking noise?? what is that and another question, the bolts that are under the pull starter, what are they holding together and can the engine be opened from that side??
thanks
thanks
ON, CANADA
RE: Locked engine
another thing when i sping the shaft shouldn't the piston move up and down, because it doesn't , all i hear is a clicking noise when i spin both the pull starter part of it and the opposite part and no piston movement
ON, CANADA
RE: Locked engine
I've just looked inside the engine and theres rust on a few spots, and the piston won't move, is this engine repairable or should i go through hpi's engine exchange program??
CA
RE: Locked engine
ORIGINAL: frankborges
ON, CANADA
RE: Locked engine
I have tried that, and i see the part that hooks on to the tranmission move, so i grabbed it and moved it myself and i watched the piston stop half way up the piston sleeve and push it right out, any ideas what that may be??
CA
RE: Locked engine
IL
RE: Locked engine
frankborges Date 8/29/2009 6:14 PM
The "transmission" is the crankshaft, the part that goes thru the bearings and flywheel and rotates with the flywheel.
The "part that hooks on to the tranmission " is the connecting rod that connects the piston to the crankshaft.
Pushing the sleeve out is normal when the engine is in good condition and still has alot of "pinch".
Take the sleeve out and the connecting rod will come off the crankshaft allowing you to remove the piston and rod as an assembly.
***NOTING THE DIRECTION THE ROD WAS FACING - I.E. WHICH SIDE WAS FACING THE CRANK***
Inspect the case to be sure there are no chunks of metal such as the piston skirt or a bearing cage floating around in there.
Inspect the piston and rod to be sure they are not cracked or broken.
Spin the crankshaft and the bearings should feel smooth as silk.
If rotating the crank feels gritty or rough the bearings need to be most likely replaced.
You will be able to see the inner bearing, make sure all the balls are there and the cage that holds them is intact.
While the piston and sleeve are out check the pinch by sliding the piston up and down in the sleeve it should get tight before reaching the top of the sleeve with the top of the piston.
Pictures would be really helpfull.
Hope some of this helps and please rate my post if it was helpful.
SLAYER
ON, CANADA
RE: Locked engine
I have looked into the engine, under the piston is rusty, the piston shaft some spots are rusty, could that be holding it back, i dunno what else to do?
ON, CANADA
RE: Locked engine
i've put the entire engine back together, now and pulled on the pull start, now i get a clicking noise, it sounds like its the little pin that cranks on the engine.......sounds like its skipping...
only thing i don't understand about this problem is that i had it running last week like mad and this week i try it and its dead in the water......... any reason why??
IL
RE: Locked engine
So if you spin the flywheel side of the crank the piston does not move...
AND if you spin the pullstart side the piston still does not move...
ON, CANADA
RE: Locked engine
yeah, when i have everything together on the engine i cannot spin nothing, all i hear is a clicking sound from the pin trying to spin the crank shaft, but when everything is apart the piston pushes up the sleeve and goes back down again, but before all of this happend, i could push the piston up and down and it wouldn't push the sleeve up.
