Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Problem with Force 26 engine
Old 11-26-2009 | 10:53 PM
My Feedback: (12)
Default Problem with Force 26 engine
Hi,
I have a Force 26 engine that was running o.k and lately started to act up. It is difficult to start and when it starts, it will not go to WOT but will quit. I use 15% nitro fuel with a MCOY 9 plug. I have also tried other plugs without much success. My high speed needle is open 3 turns. Does anybody have an idea of what I can do? Also, What is the factory setting for the low speed needle?
Le fou
Old 11-27-2009 | 04:13 AM
Default RE: Problem with Force 26 engine
i would try resealing the engine carb back plate
Old 11-27-2009 | 08:32 AM
Argess's Avatar
The Force 26 has a defiency in the block casting so that the lower carb o-ring can't seal well. If the carb loosens the tiniest bit, you get a leak. Best to seal the carb using a little RTV, especially over the ends of the pinch bolt.
This leak could cause hard starting but shouldn't have much affect on WOT running. Try richening the HSN a bit to see if that helps with WOT operation. If not, it may be starting to wear out.
Factory LSN setting is "flush", but you will find it accelrrates better when set somewhere between flush and 1 turn in
Old 11-27-2009 | 01:44 PM
argess is right
