Please Help! engine question
TN
i have a team orion wasp .26 and the backplate indents inward, so i assume i have to use a starter box for it but when i try to remove this backplate all the screws come out but on and the plate is on there still tight why is this??
thanks
thanks
It is probably being held on there by friction. See if you can get a fingernail in there and pry it free from the engine block. Too tight? Use a very small flat blade screwdriver to try and get it separated.
TN
ok ill try i just bought it though so i dont want to mess it up but then also i meant all but one screw comes out it just spins freely but ill try to pry it out
TN
the last screw i think was held in by glue or threadlocker the head of the last bolt just broke ahhh! oh well do any of you guys know where i can get cheap starter boxes??
