Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Replacing an engine
Old 07-23-2010 | 03:33 PM
Default Replacing an engine
how do you know if a new engine will fit in your nitro rc car?
Old 07-23-2010 | 04:59 PM
proanti1's Avatar
Default RE: Replacing an engine
Size: .12-.18 is a small block, .21-.32 is a big block.
Crank: Standard or SG. Standard is just threaded and uses a nut with a shaft. SG has a smooth shaft combined with the threaded crank.
Carb: Rotary or slide. Rotary means that a part on the carb rotates to open the throttle up. Slide means there a part pulls out the side of the carb to open the throttle.
Exhaust: Side or rear.
Old 07-26-2010 | 02:19 PM
Has enyone purchased the TOKI Nitro Engine (27CXP) from Hobby partz and were you happy with it?
Old 07-26-2010 | 03:26 PM
proanti1's Avatar
TOKI engines are made by Shuwa, which is a manufacturer of crappy RTR quality engines. I would advise against buying one.
Old 07-26-2010 | 05:48 PM
I ordered one before I research it so I will see what happens and after I put it through the passes I let you know if it held together. Do you know were I can find a parts brake down for this engine.
