engine has stopped
So I was giving the car some runs up and down the field for 10 mins or so whilst tuning. Just when I was getting a good tune, it stopped. When I tried to pull the pull start it was slack and loose, it would come all the way up and down without any resistence.
I took the pull start of and it unrevaled and at first I thought it was this that was causing the problem (I will buy a new one). However, when i turn the nut that the pull start normally goes over, there is no resistence there either, it just spins freely. I know this would normally turn the flywheel. I can turn the flywheel which has resitance and I can hear the pop. Any ideas what I have done? Click the link to take a look at the engine and nut that I refer to. http://img141.imageshack.us/g/sam2914.jpg/ Cheers |
RE: engine has stopped
ORIGINAL: simonRC So I was giving the car some runs up and down the field for 10 mins or so whilst tuning. Just when I was getting a good tune, it stopped. When I tried to pull the pull start it was slack and loose, it would come all the way up and down without any resistence. I took the pull start of and it unrevaled and at first I thought it was this that was causing the problem (I will buy a new one). However, when i turn the nut that the pull start normally goes over, there is no resistence there either, it just spins freely. I know this would normally turn the flywheel. I can turn the flywheel which has resitance and I can hear the pop. Any ideas what I have done? Click the link to take a look at the engine and nut that I refer to. http://img141.imageshack.us/g/sam2914.jpg/ Cheers |
ORIGINAL: 1QwkSport2.5r ORIGINAL: simonRC So I was giving the car some runs up and down the field for 10 mins or so whilst tuning. Just when I was getting a good tune, it stopped. When I tried to pull the pull start it was slack and loose, it would come all the way up and down without any resistence. I took the pull start of and it unrevaled and at first I thought it was this that was causing the problem (I will buy a new one). However, when i turn the nut that the pull start normally goes over, there is no resistence there either, it just spins freely. I know this would normally turn the flywheel. I can turn the flywheel which has resitance and I can hear the pop. Any ideas what I have done? Click the link to take a look at the engine and nut that I refer to. http://img141.imageshack.us/g/sam2914.jpg/ Cheers |
typically the writing on the owb faces towards the carb when looking at the engine from the rear
ORIGINAL: 1QwkSport2.5r ORIGINAL: simonRC So I was giving the car some runs up and down the field for 10 mins or so whilst tuning. Just when I was getting a good tune, it stopped. When I tried to pull the pull start it was slack and loose, it would come all the way up and down without any resistence. I took the pull start of and it unrevaled and at first I thought it was this that was causing the problem (I will buy a new one). However, when i turn the nut that the pull start normally goes over, there is no resistence there either, it just spins freely. I know this would normally turn the flywheel. I can turn the flywheel which has resitance and I can hear the pop. Any ideas what I have done? Click the link to take a look at the engine and nut that I refer to. http://img141.imageshack.us/g/sam2914.jpg/ Cheers Wow, thank you. I did exactly as you said, and its now working again. you've saved me a packet! |
ORIGINAL: simonRC ORIGINAL: 1QwkSport2.5r ORIGINAL: simonRC So I was giving the car some runs up and down the field for 10 mins or so whilst tuning. Just when I was getting a good tune, it stopped. When I tried to pull the pull start it was slack and loose, it would come all the way up and down without any resistence. I took the pull start of and it unrevaled and at first I thought it was this that was causing the problem (I will buy a new one). However, when i turn the nut that the pull start normally goes over, there is no resistence there either, it just spins freely. I know this would normally turn the flywheel. I can turn the flywheel which has resitance and I can hear the pop. Any ideas what I have done? Click the link to take a look at the engine and nut that I refer to. http://img141.imageshack.us/g/sam2914.jpg/ Cheers Wow, thank you. I did exactly as you said, and its now working again. you've saved me a packet! |
