PRIMING TROUBLE PLEASE HELP
Hey i have a hpi nitro mt but i just cant prime it
ive tried everything. Iv put my finger over the exaust. ive blown into the pressure tube but it wont go. its like the carburator has to much pressure. help please |
RE: PRIMING TROUBLE PLEASE HELP
1. Take fuel line off of carb.
2. Blow thorugh pressure line Question: Does fuel flow? If so, you have eliminated the tank as the source of the problem, so move onto step 3. If not, make sure you have a new or clean fuel filter. 3. Put fuel line back onto carb 4. Blow through pressure line. Question: Is fuel moving into carb? If not, then you probably have a clogged carb. Move to Step 5. 5. Remove carb and clean it. 6. Re-install carb and go to step 3. |
| All times are GMT -8. The time now is 09:24 AM. |
