RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   will it ever work???? (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/7634404-will-ever-work.html)
jamiejam 06-18-2008 03:45 PM
hello i got a brand new smartech tiger 1:10 nitro and all it is it wont start i plug the glowstick in then pull the string and yeah i did put nitro stuff in I AM NEW please dont tell me all the complicated stuff other wise i wont know but when i try to pull it the string gets stuck and then you can hardly pull it why does this happen please help i only got it today and im dieing to have a go:(
Super Mud 06-18-2008 04:41 PM
RE: will it ever work????
Since it's brand new you need to break the motor in. (look in your manual which should tell you the recomended procedure) wats happening is the piston is getting lock from too much pressure and stuff. just take the glow plug out with a nut driver, let the fuel get out by pulling the chord a couple times and for a while, spray wd-40 in the engine and pull on the chord for pretty good long time to help wear it in a bit. then put the glow plug back in and try again, repeat if needed.
TheBlazer5k 06-18-2008 04:45 PM
if your pull start is hard to pull your engine is flooded (too many fuel inside the engine)
is your glowstick charger?
check if your glow plug is glowing
jamiejam 06-19-2008 09:50 AM
right thanks for all that but now i got worse problems the pull string snapped of is easy to fix if it is and how do you fix it it?? looks like im not ment to have these sort of cars am i
TheBlazer5k 06-19-2008 10:56 AM
take a look at these
http://youtube.com/watch?v=K1_Y2ukDp4M
http://youtube.com/watch?v=pAggkhHqEkw
http://youtube.com/user/Squirrelod
these think happen when you are a beginner and you dont know any thing
you just have to learn
their is a lot of thing you have to know in the hobby
jamiejam 06-21-2008 11:59 AM
the video helped thanks but now it wont start you can hear it trying to start because it sarts for half a second does anyone have some tips?
j_blaze 06-21-2008 12:45 PM
communicating here is too slow and frustrating for you and us, go the the lhs or find a friend who has done this before. trying to explain the basics is the hardest part, the complicated stuff is easy.
NitroTherapist 06-21-2008 09:46 PM
I think your problem is that your either priming the engine so much that your flooding it or not enough that it can't stay running. Three words: READ THE MANUAL.
jamiejam 06-22-2008 04:46 PM
wwwwaaaahhhhoooo it works thanks all of you it goes well fast i ant even see it when im driving:D[8D]:)
