engine temp problem?
ok...someone plz explain to me
from reading all the forums on net....i saw lots of ppl said keep your engine under 270 or 260f but i have a kyosho GS15R and GS21R... both engines will like to run around 280 to 300f...and still got lots of blue smoke.. if i tune it around 240 to 260...they run kinda slow.... so should i keep it around 280f? or these engine meant to be run SLOW?...@_@ thanks |
RE: engine temp problem?
Check for leaks, you might want to lower nitro % or raise the head by adding a shim or two. Maybe try a colder plug.
well...i am sure there is no air leak...
and i am using 20%nitro fuel.... just wondering...maybe my engine like hot temp? |
Well, go ahead and seal the engine any ways. (it can't hurt) I have an engine that likes to run around 240 and its not sealed, then one that likes to run at 260 - 270 and the back plate and where the carb meets the case is sealed (then I sealed the carb it self, the needles with RTV and green slime) then I have a engine that likes to run at 280 - 310 and it has the back plate and where the carb goes in to the case sealed.
I'm running 30% but about to drop to 20% or 15% |
| All times are GMT -8. The time now is 03:57 PM. |
