RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   where do you temp you engine?? (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/8470168-where-do-you-temp-you-engine.html)
absolutemayhem 02-12-2009 07:16 PM
i go a 18tz im my revo. and when i temp from the glow plug ( top of head) i get 210-230. but if i check on the side of the cooling head next to the head screws i get 260+!!! its making me a little nervous, and the motor runs awsome. so should i disregard the high readings?
PrjctStrtFrce 02-12-2009 08:05 PM
RE: where do you temp you engine??
I read that temp should be taken from the top of the cooling head, but I want to see what other people say as well.
SManMTB 02-12-2009 08:38 PM
At the track. :)
rccheech 02-12-2009 11:07 PM
From the glow plug.
Argess 02-13-2009 09:13 AM
I always measure mine at the glowplug.....point the temp-gun down the cyl-head hole. The glow-plug temp is pretty constant summer or winter (with the same tune), but the fin temp can really drop on a cold day, or climb on a hot day, so it's not consistent with identical tunes.
I find it odd you got higher temps at the fins than the glow-plug. I normally would get the reverse of your readings.
fabrimacator21 02-13-2009 12:53 PM
ORIGINAL: Argess
From the way he described it, sounds like he was reading the temp on the crankcase and not the top of the head.
CR Revo 02-16-2009 10:08 AM
I've always been told you take the reading from the glow plug
jpilkinton 02-16-2009 01:24 PM
I have the Losi 2 in 1 temp/tuner and it reads from the glowplug. I have read from the fins(or top) of the head and got much higher readings.
46u 02-16-2009 04:44 PM
Glow plug.
Montana Mike 02-16-2009 04:49 PM
by glow plug do you mean the glow plug level of the cooling head or straight down from above the plug thru the head
Chris_RC 02-16-2009 04:52 PM
ORIGINAL: Montana Mike
Point the temp guage on top the of glow plug. Stright down from above the plug thru the head.
