New Engine Pre-install prep
I just received my new LOSI 427 to put into my LST2. This is a replacement for the dynalite 427 that never ran correctly for me. I would like to get some use out of this motor. So I want to do it up right if you will.
1. I am going to pull it apart and check for burs or manufacturing defects. 2. I am going to seal all gaskets with a high temp silicone -I have considered getting the marketed sealant for nitro motors but have decided to use what I have on hand and seems to work just fine. -I apply a very thin uniform layer to prevent any excess squeezing out into the crankcase. 3. Swap motor -I have not swapped motors on one of these before but I have removed my current one to inspect it. I am assuming that it will be the same except new motor goes in it's place -I will be using the original clutch and I will watch the gear mesh when I finally install it. 4. I will follow all this with a Heat Cycle Break in and hopefully begin to enjoy my LST2. Am I missing anything? Do you have any suggestions? |
RE: New Engine Pre-install prep
you may want to scuff the inside of the clutch bell to give it a little more bite.
any specifics or just 60grit paper and run a few lines length wise around the inside of the bell.
Does this drastically affect shoe life? |
it doesn't affect shoe life, it just gives the shoes something to bit into, as apposed to slipping. so it might actually increase life.
thanks for the input. I will give it a shot.
Make Sure to use the Collet that Came with the Flywheel & Not the One on the New Engine..........(The LST's Collet is Shorter than Most others) And the Engines are the Same....The Teal head has a Bigger Carb and High Compression Head Button...But other than that they are 100% the Same Engine & both made by SH Engines/Golden lion......
i need to find the parts diagram for this motor to identify the collet, as I can't place it off the top of my head.
I had heard it was a bit more powerful to push a single speed tranny. I look forward to running it. Thanks for the input |
| All times are GMT -8. The time now is 08:21 AM. |
