Carden Aircraft Post threads here related to the Carden Aircraft line
30% Carden Cap Construction Pics
Old 02-04-2003, 10:57 PM
JRozman-delete
Default 30% Carden Cap Construction Pics
Here are a few pics of my winter project. Carbon landing gear, wing tube and tail gear. 5945's all the way around. 2 on the rudder in an SWB pull pull offset tray. Hoping for < 19lb. 3w-75us for power.
Jess
Old 02-04-2003, 10:58 PM
JRozman-delete
Default Pic
Pic
Some swiss cheesing for weight.
Jess
Old 02-04-2003, 11:01 PM
JRozman-delete
Default Pic
Double beveled
Old 02-04-2003, 11:02 PM
JRozman-delete
Default Pic
In the bones
Old 02-04-2003, 11:18 PM
TERMAGATOR
Nice Job Jess...when's the completion date?....middle oF march?.....Gator
Old 02-04-2003, 11:26 PM
JRozman-delete
Default Thanks
Thanks Gator, hopefully I will get it flying by March 15. I still have about 2 more weeks of work before I start to cover.
Jess
Old 02-04-2003, 11:35 PM
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
That looks sweet Jess..... Looks like you've put a lot of work into it.... I'd like to see how they engineered the whole wing tube thing.... I wasn't very happy with the way my SuDoKhoi 60 was engineered...
Old 02-05-2003, 12:29 AM
luv2flyrc
luv2flyrc's Avatar
Default last years project
Hi , I built the 30% Carden Cap last winter, great flying plane, u will have a ball!
Here's a couple of pics, ZDZ 80.
Old 02-05-2003, 12:30 AM
luv2flyrc
luv2flyrc's Avatar
Default ONE MORE
another
Old 02-05-2003, 12:52 AM
JRozman-delete
Default Weight
Hey luv2flyrc, good looking Cap. I like the 3 blade prop. Do you have a weight?
Jess
Old 02-05-2003, 01:38 AM
rthorne
My Feedback: (29)
Jess:
Can you tell me how you cut the hole in the balsa sheeting for the wing tube. I'm building a 35% Carden Edge and I'm trying to figure out the best way to make a clean cut.
Old 02-05-2003, 01:52 AM
luv2flyrc
luv2flyrc's Avatar
Default weight
I haven't got an accurate scale.
On the bathroom job it weighs in at 20.5lbs, that's with a KS cannister slung under the belly. The cannister probably adds close to a #.
My flying field is very noise sensitive and with the 3-blade Mejzlik and KS cannister the plane is whisper quiet.
Mike
Old 02-05-2003, 04:01 AM
JRozman-delete
Default Holes
rthorne,
My hole was pre-drilled on the Cap kit. The fuse sides are 90 degrees to the wing-tube.
As I understand the edge, the fuse angles and are not 90 degrees.
I did, however cut lightening holes in some balsa sheets with a dry wall hole cutter in the drill press. Just back up the balsa with ply wood so the balsa does not splinter. Then sand. Works great.
Jess
Old 02-05-2003, 06:53 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
What size is that prop? I love the 3 blade looks!
Old 02-05-2003, 12:27 PM
luv2flyrc
luv2flyrc's Avatar
Default prop size
Hi John,
It's a 24x12
Mike
Old 02-05-2003, 12:38 PM
rthorne
My Feedback: (29)
Thanks Jess. I'll take a look for a dry wall hole cutter.
Old 02-15-2003, 06:22 AM
citation X
citation X's Avatar
Default Cap This...
Man that sure is a fine job you have done on that cap. Still shooting for the maiden on march "1" ? I'll test fly it for you
Old 05-11-2003, 01:46 AM
JRozman-delete
Default More pics
The servos. This is not per plan.
Old 05-11-2003, 01:47 AM
JRozman-delete
Default Tail
This is the tail fillet.
Old 05-11-2003, 01:54 AM
JRozman-delete
Default Spray Booth
Home made spray-booth to paint hatch.
Old 05-11-2003, 01:56 AM
JRozman-delete
Default Hatch
Stone creations Paint. Spray lite coats, it is heavy paint.
Old 05-11-2003, 01:58 AM
JRozman-delete
Default Engine
3W-75 on stand offs. I got the stand-offs from aerografix.(sp?)
Roger was great to deal with.
Old 05-11-2003, 02:14 AM
JRozman-delete
Default Pilot
I hope no one will get the wrong impression about the type of flying I like to do.
Old 05-11-2003, 02:23 AM
JRozman-delete
Default Hatch
Gluing the hatch to the hatch mounts. I used dowels on the front of the hatch so there wouldn't be so many screws to mount.
Old 05-11-2003, 02:24 AM
JRozman-delete
Default Hatch
Pic
