CEN Racing This forum is to discuss all CEN Racing products.
cen 4.6
Old 03-16-2012 | 12:24 PM
Default cen 4.6
HOWS THE LONGEVITY?i bought a cen7.7 about a quart ago and now the engine has spit,,,,,,,,,,,,,ran good last run,,,,,,,,,,,,,,what does the engine go for roughly?
Old 03-16-2012 | 09:27 PM
Default RE: cen 4.6
the part # is <span class="sr1" style="background-color: rgb(255, 255, 102); font-weight: bold; ">G70365 </span>NX7.7 Engineand on cen site or shopatron has it for $199.99 or atleast thats whats in mine not sure if it has changed since i got mine.
hope this helps
and thanks for the info on the tow angle but i ended up breaking the out drive before i could change it.
<br type="_moz" />
Old 03-17-2012 | 04:32 AM
Default RE: cen 4.6
thanx. could not find anything under shopatron
Old 03-19-2012 | 02:49 PM
Default RE: cen 4.6
no problem
on the cen racing site there is a pdf file u can download to see the exploded view of the genesis i'll look shortly to see if i can still find it. it helps alot when ur looking for parts if u didnt know. when going for parts its best to know the part number alot easier finding parts.
also to with the spit of it are u running rich? if so that could b why. mine did it and i leaned it out a little and it wasnt as much coming out.<br type="_moz" />
Old 03-19-2012 | 03:14 PM
Default RE: cen 4.6
what i meant by spit k4 is it stopped being able to run.the person i got it from told me he never took the hsn off of full rich.which would of been better than too lean but he lied cause the piston was green which means too lean.+they left fuel in it all the time causing alot of corrosion.had to be on its way out when i got it cause it only lasted about a quart.i'm curious how long these engines last cause i just got a new one.
