GEN output shafts....
Hi, I’m the owner of a Genesis 2nd serie.
It works nice but the pin of the rear dogbone (part # GS092) slipped away [:-] a bit and the central diff shaft got damaged [
] (part # GS094). I’ve also seen that the rear output shafts are a bit damaged too (part # GS029)
Why these shafts are so soft, was this problem known, are you taking some action to correct it? What could I do to solve it. Thanks for the attention.
P.s. I love your car, I'll have my first race within 15 days.... we'll see![>:]
.Why these shafts are so soft, was this problem known, are you taking some action to correct it? What could I do to solve it. Thanks for the attention.
My also have a worn Brake Drive Cup (GS094). It seems that the material it is made off, is to soft to handle de power!
I allready changed it for a new one, but this one is again going bad... I want to know what CEN has to say about this?
--[ MARI ]--
--[ MARI ]--
I have the same problem with the rear dogbone. The pin keeps comming out. Now a freind of mine will weld it, and that should make it stick.
I have tried to contact CEN, but no response. How do you get in contact with CEN?
