Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Which shock Oil in the Genesis? >
CEN Racing This forum is to discuss all CEN Racing products.
Old 09-08-2004 | 03:03 AM
Default Which shock Oil in the Genesis?
Hi,
which Shock Oil would you recommend in the Genesis shock´s ??
Thx,
Patrick
Old 09-09-2004 | 08:43 PM
Default RE: Which shock Oil in the Genesis?
I completely rebuilt my Genesis shocks and used teflon tape around the main housing to prevent any leaks. The stock O-rings are less then spectacular. I used 30 weight oil and made sure to remove all air. The shocks are much better now but are still a little slow to return. I also replaced the middle sized pistons inside the shock with the ones with the largest holes. If you are still using the number 2 pistons, then I would recommend 25 or less. Make sure every last drop of air is out of the shock. They work so much better this way.
