What make the Genesis shift
Hey again
I was wondering what is it that make the Genesis Shift up to 3rd gear is it the rpm or the mph because mine is still not shifting any where only up to 2nd but not 3rd
Please help
Please help
hey
I just wont to say that my rpm is 22954 and is it still not shifthing into 3rd. im sure of this because when i take the gear box apart the clutch in 3rd gear is like new, what is the problem im sure is not the black and silver screw because it is losen
10 turns out.
please help, enyone
michael
10 turns out.
please help, enyone
michael
probably you are already in 3rd tight all the screws, and see the speed in 1st.
then loose the screwe of the outer clutch only till whae you're happy with the shifting.
you're in 2nd
only now start to play with the 3rd
take care that you don't shift to 3rd before you shift to 2nd otherwise you'll be stuck there.
ciao
you're in 2nd
ciao
CA
Michael Emil,
A good way to get your third speed shifting is to lock down the second speed. Then soley adjust the third only. apx 8-8 1/2 turns out. Then you can start to loosen the second speed. Another way to tell if you are acheiving third speed is to feel the internal clutch bell with your finger after running. If it is warm then it has been engaging. Thanks for your question Michael.
CEN RACING
CEN RACING
If you set the third before the second ou will never shift to second or as soon as you hit second you'll shift to third.
The rpm of the shaft is what makes you shift from 2nd to 3rd...
CA
Not if you set the third speed to shift late.
CEN RACING
These are just some tips to help you out. You do not have to use them if you dont want.
CEN RACING
Ok but 8 -8 1/2 is early due to the fact that the spring are not compressed.
He should screw them in so it won't be able to hit 3rd for sure, then work on the 2nd when he's happy with it start to unscrew the 3rd....
That is what I've done and my gearbox is now well tuned.
Ciao
Ciao
Hey Cen and toto67
Thank you for the answer, and i will try both solution, I heard that there is a new clutch i can buy, can you provide me whit an order number ?
michael.
michael.
CA
Here are the recommended settings.
2nd gear 5-5 1/2 out each screw
3rd gear 7 1/2-8 1/2 out each screw
The settings will be different according to how your engine is tuned. If your engine is running rich then your engine will not reach the neccessary rpm's to make your truck shift.
Engine Settings:
Top End: 3 1/2 turns out
Bottom End: 1/2 - 1 turn in from flush
again engine settings will differ in different climates, altitudes, and humidities. These are good starting points however.
Engine Settings:
CT
LST GOD mine wouldnt shift into second either with the default factory settings that i was told to use, my second gear only started shifting when i turned both screws alittle more than half a turn out, then finally second gear started to hit within about 25 to 30 feet.
