starter probs-funfactor 2 buggy only runs with the glow stick in
somebody please help- the grass is cut short and the sun is shining ready to run my cen funfactor 2 buggy with a standard nt .16 engine...........the problem is that the thing wont run after the glow stick is taken out? ive had about 100 tanks through her- low end is at 2 turns in from flush- top end 2 and a halfs turns in. she needs about half throttle to get her going but then she dies when i take the glowie out? any suggestions
I had the same problem today with my ATX. But I primed the engine a little bit more and it worked fine, all I needed to do is play with the throttle trim. I had about 15mins out of my car until another gear stripped [:@]
patlord1: When you get your car running again, you should come to Nitronorthwests bashes, they have a bash nealy once every week.
Back to cleaning the atx
Karl
Karl
Every Sat/Sun, yep all off-road veichles are there. Someone was there today with a .46 savvy with a Truck-Zilla kit on it, awesome!
You should have a PM.
Karl
Karl
