Changing pinion gears
NE
What is involved in changing pinion gears? Does this require you to change spur gears? Can you change both the M10 and M12 pinions? All I could see was replacements for M10, which runs the first gear spur.
CA
sschuler,
Which vehicle do you have? Let me know so that I can help you better. You can change the pinion gears quite easily. There are part #'s that include all gears and clutch bell needed. I just need to know which vehicle you have.
CA
sschuler,
Here is the part # for the complete pinion and clutch bell setup for your truck. (G84309-04) Included is the clutch bell, both pinion gears and shims.
CEN RACING
CEN RACING
