atx clutch bell problems
when i first got my atx the clutch bell wobbled and jangled like mad until one day the bell sheered from the spur gears when we investigated the problem there was only one bearing inside the bell insted of the two shown on the exploded drawing
a new clutch bell was fitted with both bearings now in place
i have now put about 10 tanks through her and have found the cluch bell is working loose from the gears again !!
is this a common fault and what replacement part would you guys recomend
cheers
thelaminator2
cheers
thelaminator2
well its only the bearings within the clutch bell that locate it, so i would take a look at those. seems strange after such a short time tho... are they still a good fit on the shaft? or is that worn and causing the bearings to wobble and fail?
