Hey Mt2 guys!
Hey guys, I recently bought a MT2 and im loving it so far but its only 2wd. How can I convert it over to 4wd? I have looked thru the manuals and cant find anything about it. Please help?
Also im looking to get some good upgrades like a bigger fuel tank/roll cage. If somone could give me a link to a good website that is relyable and is neat. I would aprecheate it.
-Thanks
EnIgMa
-Thanks
EnIgMa
Apparantly the roll bar is really good for stiffening up the chassis. Personally I did my own chassis modification (as I like to tinker!) But for a lot of people it is just the ticket.
For the roll bar:
http://www.neweramodels.com/cgi-bin/...rs&part_id=372
For a 125cc fuel tank (the MT2 upper chassis brace will have to be modified):
http://www2.towerhobbies.com/cgi-bin...24&FVPROFIL=++
For a 100cc fuel tank (will still need slight modification, but is not as big):
http://www2.towerhobbies.com/cgi-bin...e2&FVPROFIL=++
For the 4wd conversion kit:
http://www.rcmodels.com/rc-cen-ffs026.html
Do check out the posts here, there is a lot of useful information.....Cheers....
For the roll bar:
I was told that you can easly convert it to 4wd this is why.
I have a drive shaft going from the gears all the way to the front 2 tires and they have drive shafts too... my guess is that their is a skrew or something missing or not tightend up that i need to... It looks like it has everything alredy thier for 4wd :/
sounds like a set screw missing or loose from one of the center drive cups... easy to fix and cheap also... mine work themselves loose occasionally.... easy way to check diffs front and rear is to turn one tire at a time.. If the opposite turns in the opposite direction, your ok... then roll the truck forward and back on the front wheels only and see if the rear turns or the driveshaft turns.. that will tell you which drive cup may be to blame.. repeat with the rears down and the front up... hope this helps..
ohh wow, i just took a look at it and the skrew is missing thanks guys for all ur help! i just gota find skrews on a site now :/
can someone give me a link to a site that sells them...
Also i just stripped my bigger spur gear [
] and orderd 3 new ones hopefully they will go on without a problem... anyone know of a fast way to switch them in and out?
the set screw is a common metric type.. I think its 3 or 4 mm set screw.. just by an assortment pack you will always use them... as far as an easy way to get at the gears... take off the whole rear assembly as one unit from the underside of the chassis.. less dissassembly and easy to change gears that way... I can changed mine in under 10 minutes... 5 if I really rush...
ok that cool well i cant find my gear that i stripped i orderd the wrong ones "got the one for the ct4s" ( but i have a ct4s i dont really like it tho... its like new and im trying to sell it )
ok well i need help becase i cant find these gears all i can find is the one for the 1-speed
i need the back gear ( big one ) but if i can get a link to both of them so i can get a fiew spare's i would aprecheate it. Thanks
i think i found the back one...
http://www.rcmodels.com/rc-cen-g84307-01.html
now i think i found the front one
http://www.rcmodels.com/rc-cen-g84307-02.html
You can order all the correct gears from the site that is in your post.
Their is a parts list on http://www.toyhaus.com/ff4wdmt.html with a link to the 2 speed transmission. You can order from toyhaus or get the part number from them and order from rcmodels. Just use the part number in the search bar at rcmodels.
rolland
rolland
wow that is exactly what i needed THANKS alot and i have orderd exacly what i needed! now its the wait of getting them [:@] my car came with was just a book of a 1 speed tran but that pic of the 2 speed really showed exactly what i needed thanks man.
-EnIg
-EnIg
that link rolland gave out could do with being a "sticky post" i reckon - its sooo useful when owners get stuck.
just a thought if any admins drop by...
