Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Why Cnt i here my mt2 shift? >
CEN Racing This forum is to discuss all CEN Racing products.
Old 06-01-2005 | 09:18 PM
Default Why Cnt i here my mt2 shift?
i just bought my mt2 about a month ago. although it runs smoothly and never had any internal problems, there is just 1 question i have. How come i can not here my truck shift. its a two speed and runs quickly but cannever here it. does anyone know why?
Old 06-01-2005 | 10:36 PM
azzman's Avatar
Default RE: Why Cnt i here my mt2 shift?
Maybe because its not shifting!! Refer to instruction manual on how to adjust it. From memory loosen the adjustment screw on the pinion gear (make sure you get the right one as there are 2 screws) to allow it to shift sooner. If its running too rich it may also not shift into second.
Old 06-06-2005 | 06:45 PM
Hold the truck up in the air and slowly roll the throttle on. Your waiting for the truck to !QUOT!kick!QUOT!. If you don't feel it kick try loosening the shift adjustment screw 1/8th turn and repeat until you feel the truck kick.
If you just cant feel it shift make sure the setscrew on the shift unit its self is correctly tightened down onto the flat spot. That is the larger set screw you will find when adjusting the shifter. Refer to the manual for more detail. Then gently tighten down the shift adjustment screw until it bottoms out the spring. Unscrew 5 1/2 turns out. That should get you pretty close to where you want to be.
Old 06-06-2005 | 07:39 PM
your truck is not shifting if you don't hear it.. mine with the stock motor usually shifted into 2nd after about 80 to 100 feet provided the engine is tuned correctly... with the new os .18... it shifts into second in about 40 feet and flies.... turn adjs screw in very small increments until shift point is reached...
