CEN Racing This forum is to discuss all CEN Racing products.
Foam inserts for mt2
Old 06-13-2005 | 01:02 AM
Default Foam inserts for mt2
Any suggestions on inserts for the stock tires? Thanks.
Old 06-13-2005 | 01:24 AM
Default RE: Foam inserts for mt2
The stock tires don't really need inserts because they are already stiff enough.
rolland
Old 06-13-2005 | 02:03 PM
Rolland I agree to a point... I made my own inserts using soft foam and basically cutting out a donut.. works well for my application which is jumping and racing... they used to flex too much before and this helped alot.. If you do this, use old mattress foam as it is soft and has good memory... just avoid getting it too wet or the tires become too heavy...
Old 06-13-2005 | 04:59 PM
Thanks for the advice, I will try the foam mattress idea.
