CEN Racing This forum is to discuss all CEN Racing products.
My Genesis LE HELP
Old 09-26-2005 | 06:20 PM
Default My Genesis LE HELP
Hey everybody i recently bought a Genesis LE so i thought can someone tell me the Aluminum Diff hosing can u see the Aluminum on the outside of the housing and also the LE that i bought also had a blue normal Genesis cover on it but the guy swears blind that it is a Genesis LE it does have the extra Tranny mount and the stronger Gears but i am just not 100% it also has the MX3 radio which i love but any way some videos are on there way hope u all like.
P.S.- Remeber i am still getting used to it LOL.
Old 09-27-2005 | 12:24 PM
Default RE: My Genesis LE HELP
U have to open the diff housings to see if there is ali diff upgrades in side! So you need to strip the rear diff ,gearbox and front diffs to see if you have the upgrades inside if you are unsure,the only way to see it.The LE comes with all the ugrades fitted as standard so i think you have nothing to worry about if you got it brand new!
Old 09-27-2005 | 06:01 PM
Thanks RunX i will do that tonight i have just purchased the Roto start for it so that should solve my pullstart problems and all i have to do know is tune it so it runs beautuful also i have seen a racing head for the NX76 that i can buy what would you sugest
Old 09-27-2005 | 08:37 PM
Hi Scotttty123!!
I have 2 option heads for my genesis. I have a nova racing and a crazy nut racing head, and all I can say is to goooooo with the CRAZYNUTHEAD.... it's awesome.... you can't get disappointed.
Hope this helps.
Old 09-28-2005 | 12:12 PM
The stock coolinghead on the Gen is fine and i never have overheating problems.Sometimes after-market coolingheads can make engines run to cold and that can be a problem for winter running and tuning.The stock coolinghead on engines are there for a reason and the factory racers cant be wrong as they use the stock coolinghead for racing!
Dont't get me wrong,aftermarket heads do look good and add some bling to your ride but is it really necessarly?
