carb settings for CEN RTR
anyone have the manual for a CEN RTR ... it's an Alfa 156 road car .... just need the number of turns for the high and low speed needle to run it in and then tune it up
like the running in procedure
thanks
I.F.
thanks
I.F.
You can download the engine manual from www.cenracing.com it will have all of the settings needed for the NT 16
rolland
rolland
CA
I have the GX1 Nitro with the NT 16 engine. The manual says to set the low end mixture screw flush with the throttle arm. It then says to tighten the high end screw until it stops and then turn it out counter clockwise 3 1/2 turns. Let me know how your car runs. I've had a little success with these settings however I still had to make a few more adjustments.
