need radio/servo help.
i have a cen gx1 nitro.I took the whole car apart and cleaned it.i put everthing back were its souposed to go.My problem is that my radio wont move any servos.The MHz are both the same 26.995.I have no clue wat to do....
IA
sounds like you're not getting any power to the receiver or transmitter. you could try turning the car on and see if you can move the servo by hand easily if you can the problem is w/ the car if not the prob is the transmitter.
I have no idea how much experience you have so I am going to ask,
What radio gear are you using? if you have to replace the receiver it might be cheaper in the long run to go for CEN's radio swap program.
Is the battery fully charged or if you are using alkalines are they any good? If they are good try plugging the pack directly into the receiver do not plug it into the on/off switch.
Did the receiver get wet or possibly damaged somehow?
rolland
rolland
ORIGINAL: dice21
