CEN Racing This forum is to discuss all CEN Racing products.
nemesis race setup
Old 11-28-2005 | 12:12 AM
blackrain's Avatar
Default nemesis race setup
what setup you guys run on the nemesis when you raced it what oil in front center and rear diff also what shock oil right know the truck seems a little bouncy and what steering servo stock servo doesnt seem strong enough turns a little wide need some thing with more torque
Old 11-28-2005 | 11:17 AM
blackrain's Avatar
Default RE: nemesis race setup
hmm???
Old 11-28-2005 | 12:25 PM
If you look at the cen website under genesis you'll find the setups. I would think they would be pretty close to the nemesis. Go to rc racing and they have the setup sheets there
Old 11-28-2005 | 11:30 PM
blackrain's Avatar
thanks
Old 11-29-2005 | 05:22 PM
Most Recently I have been running the following:
Shocks: NEMESIS upgrade aluminum Shocks. #3 pistons all around.
Front: 25wt oil
Rear: 15wt oil
Differentials:
Front: 10,000 wt
Center: 100,000 - locked
Rear: 5,000 wt
Maximum down travel.
Ride Height:
Front: Dog bones just above level
Rear: Dog bones level
Toe In: 3 degrees in the rear.
0 degrees in the front.
Camber: - 3 degrees front and rear.
Old 04-03-2006 | 12:56 AM
Andrew, I'm guessing that this set up is for a high bite smooth track? If it is, can you tell me how you would change it for a dusty, sandy, low bite, rough track? I'm thinking of going to 50k center diff oil in order to have a little "give" in the drivetrain.
