CEN Racing This forum is to discuss all CEN Racing products.
What do you guys think?
Old 12-10-2005 | 09:40 PM
BAMF90's Avatar
Default What do you guys think?
Should I wait for the Cen Magnum NX or should I get the Cen Fun Factor MT2?
Old 12-10-2005 | 09:53 PM
alvinl's Avatar
Default RE: What do you guys think?
I think I would wait for the Magnum. CEN stated they upgraded the drive train and made it better. If that is true, it will be worth waiting for. The diff cups on the MT2 need to be modified or they will not hold up and everyone is waiting to see if the new ones are better. Also, you get a larger motor.
Old 12-10-2005 | 11:52 PM
BAMF90's Avatar
A larger motor on the Magnum you mean right? What motor would you recommend?
Old 12-11-2005 | 10:18 AM
5150_UK's Avatar
ORIGINAL: ilikenitrorccars
I would recommend you to stop making a thread for every single question you (ok one or two exceptions like above) want to ask us for starters. Out of the countless threads you've made already, i'm sure it's not impossible to bump ONE of them instead of creating another thread, clogging up the forum. Another option is to use this amazing utility called a search engine - www.google.com.
Ask yourself this - why buy an old car when there's a new and greatly improved version coming out fairly soon?
The Magnum comes with a new .18 engine as standard, and judging by the way the MT2 performed with the NT-16, i'm sure there'd be no need for an engine upgrade straight away, if at all.
Old 12-11-2005 | 05:10 PM
no kidding just read on the cen website it tells you just about everying you have asked
Old 12-11-2005 | 05:38 PM
Im in the same position to. I think im going to get the fun factor because im only 10, and to have to wait for something is hard. Besides the Fun Factor already has parts and stuff out, and im new to nitro so i dont need anything to fancy. I say Fun Factor, because you can always build on it to.
Old 12-11-2005 | 09:35 PM
BAMF90's Avatar
Should most parts for the Fun Factor MT2 like New Era aluminum suspension arms fit the Magnum NX?
Old 12-11-2005 | 09:52 PM
alvinl's Avatar
Yea, it looks like most parts will be interchangeable. I am not sure I would go with the aluminum arms though, you will just break the diff housing instead of the arm breaking. Or, bend the arm. I have had a couple nasty wrecks with mine and the arms did not break. I even had one arm flex so far it popped a shock off the shock tower and bent the pivot ball that it mounts to and the arm did not break.
Old 12-11-2005 | 10:16 PM
Why wait, there's the Nemesis, you can have right now.
Old 12-12-2005 | 01:55 AM
I was just looking at the parts list on the magnum. On the 16 page toward the top it lists metal spur gears. FF102 and FF103. Wouldn't that just eat up the aluminum pinion gears. I didnt know if anyone else noticed that, so I thought I would point it out
Old 12-16-2005 | 12:37 PM
poor judgement's Avatar
ur right, the alloy pinions wont like it, but the steel 1 piece pinions and bell work ok with steel spurs.
bloody typical the steel spurs are coming out now... i sure wish cen had said something instead of ignoring my posts about steel spurs - it would have saved me a lot of time and money.
Old 12-16-2005 | 01:20 PM
pj you're a pioneer for the funfactor if you wouldn't have done it they probably never would have. I finally got all the parts I need for mine and it put back together. It's colder than he** here but I don't care I'm running it later, it's been to long.
Old 12-16-2005 | 01:46 PM
yes it will be very interesting when the magnum comes out with it's upgraded parts to use on the mt2.. should have a pretty formidable truck a few months down the line
Old 01-08-2006 | 02:35 AM
I need to get a replacement engine for one of my Cen Fun Factor's. I have already tried OS .18 CV-RX. I was thinking of trying a CEN Engine. Does anyone know if the Magnum's NX-30 .18 engine is a direct fit for the Fun Factor. I would consider buying one instead of the NT-16 factory engine. Thanks to all..
Old 01-08-2006 | 03:35 AM
alvinl's Avatar
I think the NX-30 should be a direct drop in for the funfactor. Did you have a bad experience with the OS .18 CVRX?
Old 01-08-2006 | 10:50 AM
check cens site to see if they still do their Engine Exchange Scheme, could save u a few $$
was the CVR-X too much power? wondering why u would consider a cen motor over that $90 little gem...?
