CEN Racing This forum is to discuss all CEN Racing products.
diff fluid cen matrix??
Old 01-03-2006 | 12:56 AM
My Feedback: (7)
Default diff fluid cen matrix??
hello.. i need some help on diff and shock fuids in my new cen matrix. i had problems at first with this buggy. i race a revo. and this is my first 1/8 buggy. i thought id try one. any how the first thing the sun gears in the center and rear diff broke locking the diffs. needless to say it would not turn. any how i got parts. by the way the buggy was not even a week old. it happened in a parking lot braking it in. any how i put in the new stuff. and used the shims and shimmed them.. i was told they were tight from factory. so ive now got it going. took it to the track. so far so good. no more broken gears. and i ran about 5 tanks of fuel thru it. it wants to push in the turns. i put on new panther switch soft compound tires and it helped alot. but it still pushes in the turn. ive got 5000 rear 10000 center and what ever came in it stock in the front.. i havnt taken that apart yet. for shock oil ive got 25 in the front and 30 in the rear. ive played with camber a little. and took some collars out of the shocks to soften the springs. ive got none in the front and one big spacer in the rear. any how id like to know a descent set up to start with. i got a bunch of new shock oil and some other diff fluids to try. any help would be great like i say im new to this but am anxious to learn.. its deffinetly different then my revo. it was alot of fun running it. and it jumps great. thing flys like a bird. i was bummed about the diffs. i hope that was the only bad thing that happens. other then common things that happen. welp if any info,i could use it.. id like to get this thing handling good so i can get to learning more.. thanks so much for any help.. bill
Old 01-03-2006 | 01:05 AM
Default RE: diff fluid cen matrix??
Change your diff oils to 5/7/1 and adjust from there accordingly....that should get you close. For the shocks try 35f/30r
