Car Veers to Right
hey. i got my fun factor atx up and running great. my car does veer greatly to the right. is there anyway to fix this? anything i can do on the remote? Anything i can do on the car? thanks. justin.
FL
You can adjust the st. trim, or the steering trim on the controller. Get behind the car and turn that knob until the wheels straighten out. Do this with all the electronics on.
Andy
Andy
OH
mine did the same(ct4s this is), and the st. trim. didnt go as far as my tires needed to turn, so i adjusted the tie rod. then adjusted the st. trim ... just food for thought
Set the St. Trim on the radio to 0 (center) then adjust the turn buckle to the servo until the wheels look like they are close to strait as you can get them and then fine tune with the St. Trim.
If non of the above work... check you dont have one of the right wheel nut done up to tight or a binding drive shaft on the right
