CEN Racing This forum is to discuss all CEN Racing products.
car pulling
Old 01-17-2006 | 07:29 PM
Default car pulling
hi, i'm having trouble with my cen ct4s. when ever i accelerate it pulls to the right and it's also a bit unstable at high speeds. what would be doing this?
Old 01-17-2006 | 07:45 PM
Default RE: car pulling
Oh yeah, and i did put diff silicone in the diff, but the diff was leaking!! whats up with that, diffs on my other cars don't leak, and nothing is broken on the diff, and the gasket is fine. weird.
Old 01-18-2006 | 01:26 AM
Try to adjust the toe-in to point inside.
Old 01-18-2006 | 05:20 AM
i've got the rear of car with toe-in pointing in and front toe in pointing out, got it the same as my other car, cause my other car would pull to the left if the toe in on the front was pointing in
Old 01-27-2006 | 09:11 PM
are your pins for the wheel locking nuts in? i didnt tighten a wheel properly and one pin fell out and was doing this.
Old 03-16-2006 | 01:03 PM
Front toe pointing out WILL cause wander. Real cars use just a smidgeon of toe-in, 1/32" or so usually.
You can get faster turn in by going to 0 toe, but no reason to go negative unless your racing in a cereal bowl.
