Can't start Nemesis anymore :(
Hi,
Im pretty new to nitro cars and just got my Cen Nemesis.
Please help i just cant start nemesis anymore ...
This is what i did :
- From brand new, i let the motor run-in a couple of tanks, no problem.
- After this i did drive it slow and easy- put in after run oil. - no problem.
- Next day i drove again slow and easy- put in after run oil. - noproblem.
- Next day the pull string broke
, and i installed the roto-start parts and using a drill to start the engine - no problem.
- Next day i could'nt start it at all...
I've been reading and reading and cant find the solution ..
This is what i allready checked for :
- I Checked the engine for flooding, screew out the burn plug and put the engine upside down. - No flooding.
- Replaced it with new fuel.
- Tried to put a drop of fuel inside the top below the burn plug - it started but stalled after 1 min.
- Tried to turn carburator screew clockwise to close it and turned it counter clockwise 3 1/2 full times - No results either.
- My glow starter is fully loaded and my glow/burn plug work fine - Took it out and tested it.
- There are no cracks in the engine as i see, and no leaks or what so else, i think.
- The fuel goes fine from the tank to the carburator when i block the exaust.
- I have also tried to manually "speed up" (throotle) when trying to start.
- I have valso been trying to start the engine inside, when the engine had a livingroom temperature.
The exaust is dripping (3-4 drops) from the hole with some oil'ly stuff, after trying to start, is this normal..?
Can anyone help me to start this beast again ????
Best gretings
Michael - Myreguf
, and i installed the roto-start parts and using a drill to start the engine - no problem.- Next day i could'nt start it at all...
Best gretings
)Michael - Myreguf
Hi,
1-open the needle mixture to 3-1/2 turns from closed.
2-Before starting your engine lose abit the glow plug because your engine is still stiff,ones the engine
started tight the glow plug
3-You might have flooded the engine too much so that will be quit hard to get the engine
started.
4-Open your trottle about 3mm before trying to start.
Hope this helps
started.
Hope this helps
FL
I've had the same problems. I have to use a 18 volt battery drill with a NEW battery. Once battery drains down a little bit it becomes hard to start. NEW battery , starts right up. Hope this helps. The roto start gun they sent sucks, use a battery drill 18v.
Hi
Thanx for the quick response.
I'll try this as soon as posible.
I'll get back to you with results
/ Michael - Myreguf
)/ Michael - Myreguf
Hi again,
Great .. .!
I've figured out that the glow plug just did'nt work anymore ..
After all thoose times i've checked the plug.
Thats life
.. .no wonder the engine would'n start LoL
Thanx to all the reply'ers
Have a nice weekend
/ Michael
Great .. .!
Thats life
.. .no wonder the engine would'n start LoLThanx to all the reply'ers
Have a nice weekend
/ Michael
