CEN Racing This forum is to discuss all CEN Racing products.
Alum Brake for the FF
Old 02-08-2006 | 03:48 AM
Default Alum Brake for the FF
I know lots of you have gone to the Alum Brake block. Is the one you guys use the same purple on offered on CEN's website? Can't seem to find the alum brake rod that goes into the block. . .any suggestions. Also as far as brake pads whats everyones recommendations?
Tiny
Old 02-08-2006 | 10:40 AM
Default RE: Alum Brake for the FF
The ali brake block is #FFS009. The brake cam shaft is #FF050. I have always found the stock CEN brake pads to be fine, it could be that you need to change the brake shoe or maybe just a small adjustment on the brake lever will make the difference.
Old 02-08-2006 | 10:54 AM
alvinl's Avatar
Here is a list of the parts I upgraded:
Aluminum brake seat: http://www.customrccars.com/product_...at=22&custom=0
Brake plug: http://www.customrccars.com/product_...at=22&custom=0
Brake disk & pads: http://www.customrccars.com/product_...at=22&custom=0
Hope this helps.
Old 02-08-2006 | 12:29 PM
I did the same as alvin and now my FF can do stoppies no problem
I was thinking about getting that aluminum spur/brake hub but i haven't as of yet.
Old 02-08-2006 | 03:12 PM
Thanks guys ill order those things this week.
Tiny
