CEN Racing This forum is to discuss all CEN Racing products.
nemesis axle
Old 03-07-2006 | 07:20 PM
Default nemesis axle
Just would like to post on a upgrade to the nemesis axle. Upon the investigation on the nemesis steer straight I noticed that the axles had some play inside the 23mm hex adapter. So I went to ACE hardware store and bought 4 short screws and 4 washers that are just big enough to cover the O.D. of the 23mm wheel hex. This made the axle tight with the wheel hex. Will post pics later. (I did use loc- tite to keep these in place)
Old 03-08-2006 | 03:15 AM
Bash-m-up's Avatar
My Feedback: (7)
Default RE: nemesis axle
Please do post pics of exactly what you did if you can, or pm them to me. Very interested. Thanks.
Old 03-09-2006 | 07:34 PM
here are the pics. I think that it helped.
[img][/img]
ID:	423280   Click image for larger version
ID:	423281   Click image for larger version
ID:	423282   Click image for larger version
Old 03-09-2006 | 07:50 PM
Ing
Hey cemepoo, how do you like those Commando Bead-lock wheels. Are those the 40 series? Same offset as the stock ones? Do you have any problems bottoming with the smaller diameter? Any help would be appreciated. Thanks in advance.
Old 03-09-2006 | 10:19 PM
Haven' drove truck eniugh to give a good report yet. I do think that it handles a lot better an the pavement. Does not try to roll as much. I also lower my suspension in the front to run the pavement style races. I think the wheels a spaced in teards the truck some, but the wheels ar wider than stok. Dont know all theh spec?
Old 03-09-2006 | 10:21 PM
blackrain's Avatar
what size are those screws
Old 03-09-2006 | 10:28 PM
jombo's Avatar
the screw size are either a 10/32 or a 8 /32. i know their the same size as in the metal electical box screws.
Old 03-10-2006 | 09:30 AM
I dont remember, i took the broken part of that axle up to hardware store and fitted it. Same with washer. Just remember they have to be short enough not to hit the allen headed set screw that holds the wheel hex on.
Old 05-01-2006 | 10:43 AM
Wow good deal.....have you had any broken axles with this set up?
Old 05-01-2006 | 11:50 AM
blackrain's Avatar
the new CEN axles are out already im currently running them they beefed up the shaft buy making the set screw that holds the drive pin in place smaller
Old 05-01-2006 | 12:40 PM
where did you get them?part#
I bought my nemesis about a week or so and broke two already.
Old 05-01-2006 | 01:20 PM
I think they are the same product number as the original axles. Just make sure that which ever distributor you order from gets them straight from Cen, so you don't happen to get the old axles.
Old 05-01-2006 | 04:21 PM
blackrain's Avatar
yes they are the same part number i had my local hobby shop order it directly from Cen to make shore i got the new ones. the set screw is almost less than half the size smaller than the original thats how you will know you have the new ones
