Nemesis: Steering issue, and better pivot ball?
RI
Hi everyone,
I found that my wheels won't turn on my hardwood floor when they are on the ground. I have a DX3 radio in, an Ofna 1400mah 5 cell hump pack, and the stock servo. Anyone else's wheels not turn when they are on the ground using the stock radio or similar set up?
Also I just turned on my Nemesis for the first time, and found that my steering wasn't straight. Instead of having the trim off center to begin with, I decided to center the steering arm. So i took it off, but I found that the pivot ball that holds the first linkage to the servo arm (has a philips head) is made of very soft steel, so that I've already chewed up the head a bunch. I'm sure the next time I take it off, the thing will be toast. Can anyone recommend a pivot ball that is the same size that is better, preferably a hex driver version? Maybe a Traxxas suspension pivot ball? Just hoping someone else has had this issue and replaced it so I dont have to go and try out a whole bunch of them.
Finally, I've got one pet peeve to state: Why did CEN use the little red two prong connecter on the end of the switch? I have rarely seen hump packs that use this connector, most often they are futaba j type. Why couldnt they have used that on the battery pack and the end of the switch?
All in all though, I'm still very impressed with the machine. Hopefully I'm even more impressed when I get to run it!
Al
Al
mine doesnt turn the wheel when the truck is sitting on the ground eather and i have a jrz9000t 330 oz torque with a 1400 mah pack i still need to run it and see if it turns sharp when running. i think the servo saver needs a stiffer spring it opens up when you try and turn the wheel and mine is titened down pritty tight and it still gives
CA
Hi,
The servo will not turn the wheels when the truck is sitting on the ground. This is common. The servo will move if you have an aftermarket 5 cell battery pack installed.
RI
Cen, are you saying that with an aftermarket 5 cell pack that the wheels will turn when the truck isn't moving? Because like I said, I have a 5 cell Ofna 1400mah pack in the truck and it won't turn the wheels standing still.
