CEN Racing This forum is to discuss all CEN Racing products.
Converting MT2
Old 03-21-2006 | 09:28 PM
JonnyLightening's Avatar
My Feedback: (8)
Default Converting MT2
I was wondering if anyone with a Fun Factor MT2 converted it to 2WD and if so how did you like it.
Old 03-22-2006 | 09:31 PM
Default RE: Converting MT2
only when something broke in the driveshaft... and to answer your question.... NO... i hated it!!!! drove horribly and kept spinning out.... ok on pavement but thats not what the truck is about.
Old 03-22-2006 | 10:53 PM
alvinl's Avatar
I drove mine for a while without the center driveshaft when I lost a set screw, but it drove like crap.
Old 03-23-2006 | 02:45 AM
Yeah its pretty much uncontrollable fun for donuts for a while, but that gets old real quick when it just starts to do it on it's own.
Old 03-23-2006 | 12:32 PM
poor judgement's Avatar
taller gearing and/or a tmaxx wheel conversion will calm it down in 2wd. mine is fine in 2wd with a 14t pinion and 43t spur, on tmaxx wheels - even with the .28 behind it. tbh i prefered the way it drives, never been a massive fan of 4wd, even with 1:1 cars, RWD is just so natural i reckon.
failing that, cen did make a 2wd ff, think it may have been the st... anyway, that comes with a slipper clutch setup i think - maybe worth investigating that a bit further if u really want it 2wd - it does free up a good bit of power btw.
Old 03-31-2006 | 07:50 PM
The only good thing I found with 2wd is that when you do big jumps you can alter the way the truck lands by using the throttle/brake as the unbalanced force on the rear throws the back of the car. It takes a hell of a lot of pratice and some broken parts (I strongly suggest a roll cage) but its worth it at a skate park or somewhere where you can really show off and feel really smug.
Old 03-31-2006 | 07:59 PM
azzman's Avatar
I just built up a 2wd for racing, slipper and all, its got a OS 12 in it. Havent got it running yet tho. But I have run my other MT2 in 2wd when I broke a cup early on, I didnt mind it with standard wheels but with smaller wheels its a real handful alright!
Old 03-31-2006 | 10:08 PM
I convert to 2wd when I break parts..
I'm running 1/8th wheels with big soft pin tires in the rear.
Truck HOOKS UP LARGE on grass and takes off like a rocket.
I like RWD better for high speed because you can drift the rear end and turn a LOT sharper. You learn throttle control FAST because parts are expensive and at first its undriveable.
4WD is sweet for when I want to do some jumps or climb dirt mounds and stuff.
Old 04-01-2006 | 10:19 PM
i have no use for a 2wd(tough terain) so i will just replace parts, not convert to 2wd
