CEN Racing This forum is to discuss all CEN Racing products.
Fun Factor Spur Slipping
Old 04-05-2006 | 12:47 PM
Default Fun Factor Spur Slipping
What happens is that I can slide the Spur Gear foward and backward on the dogbone, so the little pinyon comes out and lets the wheel come disconnected from the dogbone. However I cannot find a screw to re-tighten whatever has came loose.
Thanx
Old 04-05-2006 | 01:58 PM
alvinl's Avatar
Default RE: Fun Factor Spur Slipping
I think there is a small 'C' clip that holds the gear on the shaft, but there really is not much room for it to move with the brake there. Are you talking about your gear spins freely? Does it do this in both directions or just 1 direction?
Old 04-05-2006 | 03:33 PM
I just rebuilt the whole back end and fixed it.
Old 04-05-2006 | 04:13 PM
alvinl's Avatar
Glad you got it fixed. Sometimes it's very easy to miss something.
Old 04-06-2006 | 03:33 AM
All I did was take it off road and the spur gear slipped and the pinyon fell out which allowed the spur to slip. It looked like the bearing had came loose from the holder.[]
