Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 CEN Matrix and starter box!! HELP!!!! >
CEN Racing This forum is to discuss all CEN Racing products.
Old 04-16-2006 | 06:13 PM
Default CEN Matrix and starter box!! HELP!!!!
Anyone know what mods do I need to do, to make my CEN Matrix start box compatible?? (something to the chassis, a bigger hole of the flywheel..?).
I have a new OFNA STARTER BOX (No.10247) and my matrix hav a broken pullstart. The rubebr in the starterbox doesnt reach enough.
Old 04-17-2006 | 12:03 AM
Default RE: CEN Matrix and starter box!! HELP!!!!
I used a sanding wheel and cut the edges of the chasis on an angle so the wheel just barely reaches the flywheel. I didn't make the slot bigger just a little deaper on each side of the flywheel.
I can put up pics when I get home if you don't understand what I meant.
Old 04-17-2006 | 02:44 PM
Thanks, I was thinking in doing that, I imagine we have the same idea: If you see the access hole of the FW (a rectangle), I should sand the "smaller" edges (I dont know the term in english).
Do you used a shorter engine mount? because i saw in your signature you are running a different engine or just with that mod, the FW will reach the wheel of the Starter box?
Thanks for the info.
Old 04-18-2006 | 06:08 PM
Actually I have spacers(1.5MM) to raise my motor even higher because of the large pullstarter on it. So it should reach yours much easier then mine.
Old 08-03-2006 | 02:28 PM
do you have to do the smae mod for the pro kit?
Old 08-03-2006 | 08:33 PM
jaywax's Avatar
HOLD ON PEOPLE!!! You do not have to make any mods. I just set the pegs on starter box and that was all. I still have my pull start on. It works great.
