CEN Racing This forum is to discuss all CEN Racing products.
first cen product
Old 05-08-2006 | 06:55 PM
Default first cen product
getting the Gen/ in a couple days, my first Cen product, is it true that you have to idle 7 tanks, or do you guy's do it different, just want to make sure also how do you guy's rate the huge truck.
Old 05-08-2006 | 08:46 PM
Default RE: first cen product
I did the whole idle thing for about 4 tanks and then ran a little just not at full throttle for two after that.. It was on the Nemesis but should work fine. Friend of mine did only two and not has problems getting it to idle, not sure if it is from a short break in.
Hope this helps
Old 05-08-2006 | 09:08 PM
jombo's Avatar
i've posted here http://www.rcuniverse.com/forum/m_38...page_13/tm.htm
and you'll love it.
Old 05-09-2006 | 06:00 PM
hey thanks for the reply's, also is there any other thing's or problem's I should be looking for, also what type of receiver battery will be good to turn these masive wheel's.
Old 05-09-2006 | 06:58 PM
CEN Racing's Avatar
Get the highest mAh receiver pack you can. It will make a big difference.
as far as break in, just let it idle for 5 tanks and drive around slowly for 2 tanks, and you are good to go
Old 05-10-2006 | 08:55 PM
will a 1200 mah be good or should I go with 1400mah.
Old 05-11-2006 | 12:05 AM
michelob78's Avatar
Get the 1400.... they are probably similarly priced.
Old 05-11-2006 | 02:14 AM
Like Jombo posted. Look there. Also instead of idleing you can do the heat cycle method which in the end proves to be better then the CEN break in. http://www.johnnycoolguy.com/JCGR/ma..._break-in.html
Old 05-15-2006 | 06:40 PM
well got her in today, man what a beautiful truck, massive, love the whole look of it, well I should be doing my breakin on sunday, also I brought the back plate for the roto-start, but is say's on the engine, don't use it until you have a gallon thru engine, alot of blister! anyway how is this engine compared to the other well know engines, like the title say's my first cen, hopefully it should work out fine, also can I use 08 glow plug's, or any number 8 plugs.
Old 05-15-2006 | 11:57 PM
Banned
8s should be fine, McCoys 59 are a fav of mine. grats on teh new ToY. have fun, and remember fustartion releife is only a read away..
Timmahh
