CEN Racing This forum is to discuss all CEN Racing products.
Will these fit?....
Old 05-10-2006 | 02:44 PM
Default Will these fit?....
Will a set of Genesis rims and tires fit on a Magnum NX?
Old 05-10-2006 | 03:24 PM
Banned
Default RE: Will these fit?....
well its just common sense 19 mill cant fit on a 14 or 12 mill,wat eva it is so ,,,,,,,,,,,,,,,,,,no they wont fit
Old 05-10-2006 | 06:14 PM
CEN Racing's Avatar
Probably not because the NX wheel axle is a 4mm axle with a 14mm hub, and the Genesis wheel axle are 8mm axles with 19mm hubs.
Old 05-10-2006 | 07:17 PM
Old 05-11-2006 | 01:15 AM
Even if you somehow made adapters to fit, you would probabaly wreck drive shafts due to the size and weight of the genesis wheels.
Old 05-11-2006 | 02:20 PM
CEN Racing's Avatar
ORIGINAL: dustin7837
I agree with that comment too! You will put even more load on the drive train.
