gen/nem owners hsn setting
CT
hi guys, just wondering what are your hsn settings on your trucks. my hsn is at 4-1/2 to 4-3/4 out, i never had a truck that was that thirsty. i'm running wildcat 20% w/11%oil, just wanted to know if others were the same way.
thanks guys, just wanted to check with others before i checked for airleaks
CT
CA
So you know, every engine will have a little different settings on it. The 3 1/2 turns out on the high needle is just the factory suggestion. Your engine may need a higher or lower setting depending on its needs.
CT
ok, so what your saying is that its normal to run at this setting, and i prob dont have an air leak since both the nem and gen are doing this.
got it, thank you cen for your help.
