Genesis LE Transmission
First off all I would like to thank eveyone for there help!!!!!!!!!!
I ripped my transmission out of me Genesis because I noticed that my second gear cluch is frozen on the outside housing so I took it out and I want to replace it or tear it apart to clean it up and start over. The truck is currently stuck in second gear so its a slug off the line and top end is only about 30-35. Can somebody give me some advice on how to remove this clucth so I do not damage it. I was in the process of taking of the C-Clip on the other side of the transmission then I thought I would ask questions before I tore it up.
Steve
Steve
Hey,
On page three of this document link you will see the parts to remove to get the second gear off the transmission. the nut is now a T-bolt(looks like a shaft with a hole drilled thru the side of it). Put and allen wrench of the right size thru the hole and another allen wrench thru the hole on the other end of the same shaft twist to the left. Unthread the T-bolt and firmly tug on the gear and it should come off.
There you have it I hope that helps
http://www.cenracing.com/cars/genesis/manual07to12.pdf
