Magnum NX clutch problem
Hello...
What's the default setting for the clutch?..i mean..how many turns does the little screw in the clutch unit must have?
The problem is that i'm pretty sure the second speed is not engaging....how can i solve this? i asked at the place where i bought the magnum but the settings they told me are not working...
Thanks for your help...
i think its 3.5 - 4 turns out from fully screwed in. careful u dont crucsh the spring when screwing in tho!
sometimes the engine tune drifting out a bit can cause shift problems too.
just to complicate it further, theres a chance u are running in 2nd gear straight away if the adjustment screw is too loose...
