Matrix Update
TX
I raced my Matrix for the first time yesterday. The buggy is rock solid and handles well. A lot of people were impressed with the large shocks and the beefy suspension parts. The only problem I had was with the temps. The engine flamed out once. It was as high as 340 degrees. I used the needle settings from Cen and it continues to run extremely hot. It is confusing because I had a nice trail of blue smoke. I am going to go out this week to try and find the correct settings for this engine. Other than the engine problem, the buggy was awesome.
TX
I think I fixed the temp problem. I used the settings HSN: 3 3/4 turn out, LSN: 4 turn out, Mid: 1/2 turn from flush.
I start the motor a little lean on the HSN, I let it heat up pretty good then set it to these settings above. I take it slow around the track for one lap and it is good to go. I ran two tanks through and the temp were 262. The key is to let the motor warm up really well then set it to these settings. It may sound rich, but it has enough power to carry you through jumps and tight turns.
The buggy is durable as hell. I have had some tough landings and it did not blink an eye. The Matrix is solid as a rock.
