replacement needle
FL
were can i buy a replacement adjustment needle for nt-16 (http://www.cenracing.com/engines.html) or is there one from another engine that will work with this one?
My Feedback: (7)
KY
Generally you can simply replace the needle with any other needle from other small block carbs. Simply thread in the new assembly from the donor. It may not have the same setting for the other engine as the old one did but it should work fine. I have swapped a .16 to a .18 and a .15 to a .12 in many cases just like yours. All of them work fine, the reasons I had to swap was I broke two, one on the .12 and the other was my .18. I had replaced the with the .16 and .15, and they were each made from different mfgs. So I will venture to say they are all interchangable. Just be sure to swap the whole needle assemblies and not just the needle, brass sleeve, fuel nipple, gaskets, etc. Good luck and let us know how it works out for you.
AB, CANADA
Go here http://www.cenracing.com/downloads/engineparts.xls
and click on the NT NX sheet at teh bottom.
It lists all the part numbers and prices for the CEN engines.
Then just contact the CEN dealer of your choice and tell them what part number you need.
OR
Like bash says, replace the needle and hte needle seat from another small block engine.
OR
